Автор Тема: 06TV170R2  (Прочитано 280 раз)
06TV170R2
« : 29 Ноября 2023, 06:59:31 »
06TV170R2
KDL-40S2510, KDL-40S2530, KDL-40V2500,
KDL-46S2510, KDL-46S2530, KDL-46V2500
BC
Subject IRIS
Software Upgrading Procedure for WAX-2(C)T Chassis [REVISION 2]
This Technical Bulletin describes the software upgrading procedure using a Memory Stick.
Memory Stick Preparation
 Use an ordinary Memory Stick (4M, 8M, 16M, 128M, etc.) with low access. Do not use fast access types such
as Memory Stick Pro, Magic Gate, etc.
 Format the Memory Stick using a formatter, the program available on the Sony Europe site http://support.sonyeurope.
com/memstick/downloads/downloads_ms.asp?l=en&f=MSFRM, or a digital camera (recommended).
Do not use the Windows formatter.
 After formatting, the Memory Stick should only contain the file "Memstick.ind".
Update Procedure
 Unzip the "PKGxxxxE_N_ADJ.zip" file attached to Technical Bulletin 06TV171. Separate folders will be
created for the six panel sizes, viz. TM****_TH****_TS****_TD****_S32, TM****_TH****_TS****_TD****_S40,
TM****_TH****_TS****_TD****_S46, TM****_TH****_TS****_TD****_V32, TM****_TH****_TS****_TD****_V40,
and TM****_TH****_TS****_TD****_V46. Each will contain the subfolder "wax2_mheg".
 Copy the complete "wax2_mheg" subfolder to the root of the formatted Memory Stick.
 Insert the Memory Stick into the set.
