Автор Тема: 06TV168R2  (Прочитано 458 раз)
06TV168R2
« : 29 Ноября 2023, 06:57:52 »
06TV168R2
WAX-2F, WAX-2FLC Chassis BC
Subject IRIS
Software Upgrading Procedure for WAX-2F(LC) Chassis [REVISION 2]
This Technical Bulletin describes the software upgrading procedure for the WAX-2F Chassis using a Memory Stick.
Memory Stick Preparation
 Use an ordinary Memory Stick (4M, 8M, 16M, 128M, etc.) with low access. Do not use fast access types such
as Memory Stick Pro, Magic Gate, etc.
 Format the Memory Stick using a formatter, the program available on the Sony Europe site http://support.sonyeurope.
com/memstick/downloads/downloads_ms.asp?1=en&f=MSFRM#disc, or a digital camera
(recommended). Do not use the Windows formatter.
 After formatting, the Memory Stick should only contain the file "Memstick.ind".
Updating Procedure
 1. Download the "*_PKGxxxx_N_ADJ.zip" file attached to one of the documents below.
Model Technical Bulletin
KDL-40/46W2000 06TV169
KDL-40/46T3500
KDL-40V2900
08TV041
 2. Unzip the applicable package. Separate folders will be created. Each folder contains the subfolder
"wax2_mheg".
Model Folder Remark
KDL-40/46W2000 w2000_PKGxxxx_N_yy_ADJ
xxx = package version
yy = panel inches
KDL-40/46T3500 t3500_PKGxxxx_N_yy_ADJ
KDL-40V2900 v2900_PKGxxxx_N_yy_ADJ
 3. Copy the complete "wax2_mheg" subfolder to the root of the formatted Memory Stick.
06TV169 - Software Packages Follow-up for WAX-2F Chassis [REVISION 11]
« Последнее редактирование: 29 Ноября 2023, 15:40:50 от aze1959 »
