Автор Тема: 06TV167R1  (Прочитано 211 раз)
06TV167R1
« : 29 Ноября 2023, 06:56:37 »
06TV167R1
KDL-40S2000, KDL-40S2010, KDL-40S2030, KDL-40S2510,
KDL-40S2530, KDL-40V2000, KDL-40V2500, KDL-40W2000,
KDL-46W2000
BC
Subject IRIS
Caution when Upgrading the Software or Replacing the B Board [REVISION 1] 1321
Some changes have been applied on the "Inverter Board" to solve the dark "Mura" phenomenon at low
temperature.
Make sure to upgrade the software as indicated in the table below, also referring to Technical Bulletins 06TV109R*,
06TV168, 06TV170R*.
Chassis Model TVM TD Software Follow-up
WAX2, WAX2C KDL-40S2000, -40S2010, -40S2030, -40V2000 TM1320E or > TD1231E or > 06TV112R*
WAX2T KDL-40S2510, -40S2530, -40V2500 TM1011E or > TD1014E or > 06TV171R*
WAX2F KDL-40W2000, -46W2000 TM1014E or > TD1009E or > 06TV169R* & 07TV087
