Автор Тема: 06TV166R1  (Прочитано 188 раз)
06TV166R1
« : 29 Ноября 2023, 06:55:37 »
06TV166R1
KDL-40S2000, KDL-40S2010, KDL-40S2030, KDL-40S2510,
KDL-40S2530, KDL-40V2000, KDL-40V2500
BC
Subject IRIS
Caution when Replacing the Panel [REVISION 1] 1321
Some changes have been applied on the "Inverter Board" to solve the dark "Mura" phenomenon at low
temperature.
Whenever replacing the panel, always upgrade the software as indicated in the table below, also referring to
Technical Bulletin 06TV109R*.
Chassis Model TVM TD Software Follow-up
WAX2, WAX2C KDL-40S2000, -40S2010, -40S2030, -40V2000 TM1320E or > TD1231E or > 06TV112R*
WAX2T KDL-40S2510, -40S2530, -40V2500 TM1011E or > TD1014E or > 06TV171R*
WAX2F KDL-40W2000 TM1014E or > TD1009E or > 06TV169R*
