Автор Тема: 06TV164  (Прочитано 197 раз)
06TV164
« : 29 Ноября 2023, 06:53:24 »
06TV164
KE-50MR1, PDM-5000
DP
Subject
IRIS
Panel Replacement
The original panel is no longer available.
In case the panel is replaced, install the type listed below and apply the changes indicated by using the parts contained in the special kit.
Description
Former part number
New part number
Panel
9-885-060-55
9-885-081-88
Panel Sub Parts Kit
9-913-800-17
1. Replace the following parts: P Board, F2 Board, F2 Board Bracket, two purse locks on the F2 Board, four 1000μF 250V capacitors on the G Board with 1200μF 250V capacitors.
