Автор Тема: 06TV157R4  (Прочитано 294 раз)
06TV157R4
« : 29 Ноября 2023, 06:50:16 »
06TV157R4
KDL-20S2000, KDL-20S2020, KDL-20S2030, KDL-20S4000,
KDL-20S4020, KDL-26U2000, KDL-32U2000, KDL-40U2000
TD
Subject IRIS
Part number for BDT/BDTR Board per Size [REVISION 4]
The “BDT Board” (A-1198-236-A) and “BDTR Board" (A-1219-638-A) listed in the Service Manual are common
boards for the models mentioned above. Modelwise specific software needs to be written to this boards by using
the "TL Jig" (9-948-023-46). Two situations are possible.
• 1. In case the "TL Jig" is NOT AVAILABLE, preprogrammed boards with model-specific software can be
ordered as indicated in the following table.
BDT Board
Part number Description + Model
9-948-023-64 BDT Board KDL-40U2000
9-948-023-65 BDT Board KDL-32U2000
9-948-023-66 BDT Board KDL-26U2000
9-948-023-67
BDT Board KDL-20S20xx, KDL-20S40xx
* KDL-20S40xx needs special NVM data, which can be
downloaded from the attachment to Technical Bulletin 08TV020.
BDTR Board
9-948-023-68 BDTR Board KDL-32U2000 [A]
9-948-023-69 BDTR Board KDL-26U2000 [A]
• 2. In case the "TL Jig" is AVAILABLE, use the part number indicated below and write the model-specific NVM
data to the BDT Board as explained in Technical Bulletin 06TV146R*.
BDT Board
Description Part number
BDT Board with EDID Data 9-948-023-73
BDTR Board
No board available yet.
