Автор Тема: 06TV156R2  (Прочитано 194 раз)
06TV156R2
« : 29 Ноября 2023, 06:49:01 »
06TV156R2
WAX-2 Chassis TD
Subject IRIS
Part Number for "Inverter Board" [REVISION 2]
The Inverter Board has been made available for service purposes.
The correct information for the Inverter Board is indicated in the table below.
Model
Inverter Board / Kit Panel
Part number Label Part number Label
AUO
KDL-26S2000
1-789-721-11 1926006199 1-802-260-11 T260XW02
KDL-26S2010
KDL-26S2020
KDL-26S2030
S-LCD
KDL-26S2000
1-789-507-11 LJ97-00702B 1-802-061-13 LTY260W2-L16
KDL-26S2010
KDL-26S2020
KDL-26S2030
KDL-32S2000
1-789-504-11 LJ97-00717B
KDL-32S2010
KDL-32S2020
KDL-32S2030
KDL-32V2000 1-789-658-11 LJ97-00805C
KDL-40S2000
1-789-500-11 LJ97-00703A
KDL-40S2010
KDL-40S2030
KDL-40V2000
KDL-46S2000
A-1251-295-A/B
LJ97-00761A/B
LJ97-00762A/B
REMARK: The two Inverter Boards
for the 46” panel are synchronized.
If a problem occurs in one board,
replace both boards by a complete kit.
KDL-46S2010
KDL-46S2030
KDL-46V2000
