Автор Тема: 06TV155R1  (Прочитано 186 раз)
06TV155R1
« : 29 Ноября 2023, 06:47:54 »
06TV155R1
KDL-S23A11E, KDL-S23A12U, KDL-S26A11E, KDL-S26A12U, KDL-S32A11E, KDL-S32A12U, KDL-S40A11E, KDL-S40A12U, KLV-S23A10E, KLV-S26A10E, KLV-S32A10E, KLV-S40A10E
TD
Subject
IRIS
Part Number for "Inverter Board" [REVISION 1]
The "Inverter Board" of these models has been made available for service purposes.
The correct information for the "Inverter Board" is indicated in the table below.
• In case of a 32" panel, two types of “Inverter Board” are used. Therefore, always check the part number of the defective board.
• In case of a 40” panel, the two “Inverter Boards” are synchronized. If a problem occurs in one board, replace both boards by a complete kit.
Panel Size
Model
S-LCD P/N
Inverter Board / Kit P/N
KDL-S23A11E
KDL-S23A12U
23"
KLV-S23A10E
REMARK
KDL-S26A11E
KDL-S26A12U
26"
KLV-S26A10E
1-789-458-11
KDL-S32A11E
KDL-S32A12U
32"
KLV-S32A10E
1-789-420-11
1-789-422-11
KDL-S40A11E
KDL-S40A12U
40"
KLV-S40A10E
LJ97-00648A
LJ97-00649A
A-1251-294-A
