Автор Тема: 06TV154  (Прочитано 242 раз)
06TV154
« : 29 Ноября 2023, 06:46:52 »
06TV154
KDL-26U2000, KDL-32U200, KDL-40U2000
BC
Subject
IRIS
Intermittent Poor Remote Control Sensitivity
2154
Intermittent poor remote control sensitivity.
CAUSE
Infrared malfunction caused by interference from a nearby strong electrical field such as a switching lamp located at a 20 cm distance.
Connect the IR shielding of the H3 Board to the board ground as explained below.
• Scrape away the green silk layer near the ground connection (area of approximately 0.5 cm in diameter) to uncover the copper layer underneath.
• Solder the copper area to the ground connection.
KDL-26U2000 (E)
1300001~1300223
KDL-26U2000 (E)
4300001~4342684
KDL-26U2000 (K)
1600001~1603814
KDL-26U2000 (K)
4600001~4606327
KDL-26U2000 (U)
4000001~4004925
KDL-32U2000 (E)
1300001~1312689
KDL-32U2000 (E)
4300001~4333560
KDL-32U2000 (K)
1600001~1612517
KDL-32U2000 (K)
4600001~4605526
KDL-32U2000 (U)
4000001~4008878
