Автор Тема: 06TV148R1  (Прочитано 214 раз)
06TV148R1
« : 29 Ноября 2023, 06:42:41 »
06TV148R1
KDL-26S2000, KDL-26S2010, KDL-26S2020,
KDL-32S2000, KDL-32S2010, KDL-32S2020, KDL-32V2000
TV
Subject IRIS
No Power [REVISION 1] 1110
No power.
CAUSE
Defective IC6104 on the G1 Board.
It has been identified that lot numbers 5D6 and 5D8 potentially have some problem so that IC6104 needs to be
replaced if failed. Note that fusible resistor R6169 may also have failed.
Ref. Description Part number
IC6104 IC MIP2H2 6-708-801-01
R6169 Res, Non-flammable Fuse 0,47 Ohm 1-220-926-21
