Автор Тема: 06TV147R1  (Прочитано 205 раз)
06TV147R1
« : 29 Ноября 2023, 06:41:09 »
06TV147R1
KDL-26U2000, KDL-32U2000 BC
Subject IRIS
Caution when Replacing the LCD Panel [REVISION 1]
Two different types of non-compatible LCD panels (Samsung and Auo) have been used during production.
Whenever the LCD panel needs replacement, be sure to use the correct type corresponding to the serial number
ranges indicated below.
Model Serial number Description Part number
1000001~1090001
1300001~1390001
1600001~1690001
4000001~4090001
4300001~4390001
4600001~4690001
LCD Panel A-1198-389-A
1100001~1190001
1400001~1490001
1700001~1790001
3000001~3090001
4100001~4190001
4400001~4490001
KDL-26U2000
4700001~4790001
LCD Panel A-1216-609-A
1300001~1390001
1600001~1690001
4000001~4090001
4300001~4390001
4600001~4690001
LCD Panel A-1198-388-A
1100001~1190001
1200001~1290001
1400001~1490001
1700001~1790001
3000001~3090001
4100001~4190001
4400001~4490001
KDL-32U2000
4700001~4790001
