Автор Тема: 06TV140  (Прочитано 194 раз)
06TV140
« : 29 Ноября 2023, 06:36:34 »
06TV140
KDL-32S2000, KDL-32S2010, KDL-32S2020
BC
Subject
IRIS
No Power-on, LED Blinking Four Times
1110
The set does not power on and the LED is blinking four times. The LED error code indicates that the panel is defective.
Replace the "Panel Inverter Board" as indicated in the table below.
Description
Part number
1-789-504-11
IMPORTANT NOTE
Exchanging the "Panel Inverter Board" requires the same reporting as in the case of a panel replacement. Contact your local Sony Service organization for further details.
