Автор Тема: 06TV126R2  (Прочитано 225 раз)
06TV126R2
« : 29 Ноября 2023, 06:34:28 »
06TV126R2
KDL-20S2000, KDL-20S2020, KDL-26U2000,
KDL-32U2000, KDL-40U2000
BC
Subject IRIS
Intermittent Picture and/or Audio Muting [REVISION 2] 118C
Intermittent picture and/or audio muting during normal operation.
CAUSE
Data software error.
Update the set using the most recent upgrade package attached to Technical Bulletin 08TV020. The upgrading
procedure is explained in Technical Bulletin 06TV127R*.
NOTE
No NVM settings need to be changed.
APPLICABLE SERIAL NUMBERS
4301006~4301461
KDL-20S2020 (E)
4301595~4301616
KDL-20S2020 (U) 4600134~4600325
KDL-20S2020 (K) 4000276~4600325
4304507~4304566
4304720~4305072
4305441~4306232
4306668~4307854
4308103~4309630
4310896~4311619
KDL-26U2000 (E)
4311996~4312324
KDL-26U2000 (K) 4600817~4601951
4304560~4304658
4309139~4309924
4310288~4310670
4311085~4311514
4312002~4313780
4313931~4314316
4314431~4315445
KDL-32U2000 (E)
4315731~4316516
KDL-32U2000 (U) 4000001~4000244
KDL-32U2000 (K) 4600501~4601005
KDL-40U2000 (E) 4300370~4300768
