Автор Тема: 06TV113  (Прочитано 221 раз)
06TV113
« : 29 Ноября 2023, 06:28:57 »
06TV113
KDL-26S2000, KDL-26S2010, KDL-26S2020,
KDL-32S2000, KDL-32S2010, KDL-32S2020,
KDL-40S2000, KDL-40S2010, KDL-46S2000, KDL-46S2010
BC
Subject IRIS
Programme Sorting Not Saved P727
When moving the channel some 20 positions or more during the "Programme Sorting" function and switching off/on
the set by means of the power button, the label data are stored but the tuning data are not. The problem does not
occur when moving the channel over small distances.
CAUSE
Incorrect writing process.
The problem is solved from software package "PKG1040T" onward. In case of updating, however, the latest
software package "PKG1046T" must be used. Refer to Technical Bulletin 06TV112 for the necessary files.
