Автор Тема: 06TV109R3  (Прочитано 378 раз)
06TV109R3
« : 29 Ноября 2023, 06:27:15 »
06TV109R3
KDL-26S2000, KDL-26S2010, KDL-26S2020, KDL-26S2030,
KDL-32S2000, KDL-32S2010, KDL-32S2020, KDL-32S2030,
KDL-32V2000, KDL-40S2000, KDL-40S2010, KDL-40S2030,
KDL-40V2000, KDL-46S2000, KDL-46S2010, KDL-46S2030,
KDL-46V2000
TD
Subject IRIS
Data Handling Using TL3 Jig [REVISION 3]
A TL3 Board has been made available to facilitate the data handling.
Follow the procedure described below. The TL3 Board has the following functionalities:
• NVM reading and writing.
• Flash upgrade of the main microcontroller.
PROCEDURE
1. Requirements
• Pentium III, 130 MHz.
• Available USB port.
• TL3 Jig Interface (9-948-020-98).
• Software package.
2. Set-up
In the rear cover there is a small removable door that gives access to the service connector. Strengthen the
supplied flat cable by attaching a piece of hard plastic (e.g. from a printed circuit board) to the bottom side. In this
way the rear cover does not need to be removed.
06TV109 - WAX2 - Data Handling Using TL3 Jig [REVISION 3]
« Последнее редактирование: 29 Ноября 2023, 15:38:26 от aze1959 »
