Автор Тема: 06TV108  (Прочитано 244 раз)
06TV108
« : 29 Ноября 2023, 06:26:10 »
06TV108
KDL-26S2000, KDL-26S2010, KDL-26S2020, KDL-32S2000,
KDL-32S2010, KDL-32S2020, KDL-32V2000, KDL-40S2000,
KDL-40S2010, KDL-40V2000, KDL-46S2000, KDL-46S2010,
KDL-46V2000
BC
Subject IRIS
Intermittent Speaker OSD Indication, Continuous Audio Switching C550
Intermittent speaker OSD indication and continuous audio switching in areas of A2 Zweiton stereo reception with
certain signal parameters.
CAUSE
Software problem in combination with the condition of the analogue RF signal.
Update the set using the TL3 Board (9-948-020-98) and the software package PKG1046T contained in the
"DM25107.ZIP", "TD1210E.ZIP", "TM1211E.ZIP", and "TM1211ECODE2.ZIP" files attached to Technical Bulletin
06TV112. The software usage is explained in Technical Bulletin 06TV109.
PROCEDURE
1. Enter the Service Mode by pressing the following button sequence on the remote control.
