Автор Тема: 06TV102  (Прочитано 211 раз)
06TV102
« : 29 Ноября 2023, 05:15:04 »
06TV102
KDE-W50A11E, KDE-W50A12U, KDL-W40A11E,
KDL-W40A12U, KE-W50A10E, KLV-W40A10E
TV
Subject IRIS
Flashing LED when Mounted to Wall
The LED may be flashing when the unit is mounted to the wall.
Installing the separately available wall bracket SU-PW3M can solve the problem. However, if the customer does
not accept this, proceed as explained below using the parts indicated.
Description Part number
Adapter and
2.5 x 12 mm Self-tapping Screw 9-948-021-94
• Remove the stand and insert the adapter into the woofer connector.
• Secure the adapter with the 2.5 x 12 mm self-tapping screw. Make a mark on the plastic to locate the screw
