Автор Тема: 06TV082R1  (Прочитано 338 раз)
06TV082R1
« : 29 Ноября 2023, 05:04:38 »
06TV082R1
KDE-V42A12U, KDE-W50A11E, KDE-W50A12U,
KDL-V26A11E, KDL-V26A12U, KDL-V32A11E, KDL-V32A12U,
KDL-V40A11E, KDL-V40A12U, KDL-W40A11E, KDL-W40A12U
BC
Subject IRIS
AV2 Changes to AUTO [REVISION 1] S72A
The AV2 output set by the user (Menu => Features => AV2 Output) may change spontaneously to AUTO some
fifteen minutes after powering off.
Only in case of a customer complaint, upgrade the software of the main microcontroller IC1002 on the BL Board to
v1.210a or higher as explained in Technical Bulletins 05TV256 and 06TV080, using the TL3 jig and the attachment
"1210A_H8WRITER_CODE2_R1.ZIP" to this document. This attachment contains the H8Writer program as well as
the necessary MOT and initial NVM data files for the above models.
« Последнее редактирование: 29 Ноября 2023, 15:34:59 от aze1959 »
