Автор Тема: 06TV058  (Прочитано 197 раз)
06TV058
« : 29 Ноября 2023, 04:57:42 »
06TV058
KDL-V26A11E, KDL-V26A12U, KDL-V32A11E, KDL-V32A12U, KDL-V40A11E, KDL-V40A12U, KLV-V26A10E, KLV-V32A10E, KLV-V40A10E
BC
Subject
IRIS
No Flat Frequency Response via Line Out, Low Audio Level
1531
A. No audio flat frequency response via Line Out.
B. The volume has to be increased excessively before obtaining an "acceptable" audio Line Out level.
Only in case of a customer complaint, proceed as follows.
A.
Flatten the audio Line Out response by disabling the BBE feature in the Service Menu as explained below.
1. In the user menu, set the audio effect mode to [OFF].
2. Enter the Service Menu and select [Special Menu].
