Автор Тема: 05TV231R1  (Прочитано 232 раз)
05TV231R1
« : 29 Ноября 2023, 04:30:34 »
05TV231R1
KDL-S32A12U, KLV-S32A10E BC
Subject IRIS
Buzz Noise from Speaker at Low Volume [REVISION 1] 1541
Buzz noise from the speaker when volume level 1 is selected. The problem does not occur in the muting position.
CAUSE
Excessive noise from the inverter.
1. Add a 2700μF capacitor on the G2 Board between the Vcc line and GND of the audio amplifier's power supply
as explained below.
• Apply RTV133 bond at the location where the capacitor will be fitted.
• Solder the plus side of the capacitor to pins 13 / 14 and the minus side to pins 11 / 12 of CN6200.
• Bend the capacitor legs until the capacitor body gets fixed to the RTV bond.
Description Part number
Cap., Elect 2700μF 1-165-738-31
RTV133 Bond 9-948-018-13
