Автор Тема: 05TV230  (Прочитано 208 раз)
05TV230
« : 29 Ноября 2023, 04:29:18 »
05TV230
KDL-S23A12U, KDL-S26A12U, KDL-S32A12U, KDL-S40A12U,
KLV-S19A10E, KLV-S19A10U, KLV-S23A10E, KLV-S26A10E,
KLV-S32A10E, KLV-S40A10E
BC
Subject IRIS
No Remote Control Operation, Malfunctioning LEDs 121B
• No remote control operation.
• Malfunctioning LEDs.
Check the pins of CN9901 (H3 Board) and CN5405 (BE Board) as well as the cable between these two connectors.
If the cable appears to be damaged or some pins are bent, replace the cable and/or the connectors as indicated
below. When connecting the new cable to the boards, be careful not to bend or damage any pins.
Ref. Description Part number
– Cable 1-910-012-77
CN5405 Connector 10P 1-784-254-21
CN9901 Connector 10P 1-784-254-21
