Автор Тема: 05TV229  (Прочитано 227 раз)
05TV229
« : 29 Ноября 2023, 04:28:02 »
05TV229
KDL-S23A12U, KDL-S32A12U,
KLV-S19A10E, KLV-S19A10U, KLV-S23A10E, KLV-S32A10E
BC
Subject IRIS
Low Brightness with PC Input F321
Picture too dark with PC input.
CAUSE
Incorrect NVM register data.
• Check whether the model's serial number corresponds to the range affected.
• Use TRACE to check the value of the registers indicated in the following table. If the data are incorrect, use
TRACE to upload the correct values for these registers. The method is explained in the attachment
"TRACE_05TV229.PDF" to this document.
Register Incorrect Data Correct Data
0X0C2F 0B B0
0X0C3F 0B B0
0X0C4F 0B B0
APPLICABLE SERIAL NUMBERS
KDL-S23A12U 4000001~4000627
KDL-S32A12U 4000205, 4000250, 4000417, 4000431,
4000462~4000496, 4000532~4000717,
4000732~4000889, 4001233~4001259,
4001433~4001498, 4001504, 4001702,
4001756~4001824, 4001992~4002019
KLV-S19A10E 4000001~4000310
KLV-S19A10U 4000001~4000420
KLV-S23A10E 4000001~4001019
KLV-S32A10E 4000801~4001150, 4001204, 4001265,
4001300~4001393, 4001497,
4001503~4001510, 4001547~4002384,
4002528~4002541
