Автор Тема: 05TV016  (Прочитано 233 раз)
05TV016
« : 29 Ноября 2023, 04:21:18 »
05TV016
KE-42MR1, PDM-4200
DP
Subject
IRIS
One or Several Vertical Lines on Left-hand Side of Screen
1330
One or several black vertical lines may appear on the left-hand side of the screen.
CAUSE
Heat may cause cracks in the soldering portion of some connectors on the two Data Relay Boards of the Display Unit (PDM-4200) so that contact is being made with the insulation plate of the heat sink.
Replace the two Data Relay Boards and the Heat Sink of the Display Unit (PDM-4200) as explained in the attached document "heatsink_repair.pdf". The necessary parts are supplied as a "Service Kit" (9-885-036-21).
NOTE
• Only technicians who have attended the training course are entitled to perform the repair.
• Being confidential, the information contained in the attached document "heatsink_repair.pdf" is only intended for internal use.
APPLICABLE SERIAL NUMBERS
PDM-4200 (AEP)
2200001~2200785
