Автор Тема: 05TV007R1  (Прочитано 204 раз)
05TV007R1
« : 29 Ноября 2023, 04:19:04 »
05TV007R1
KE-P37M1, KE-P42M1, KLV-15SR1, KLV-15SR2, KLV-17HR1, KLV-17HR2, KLV-17HR3, KLV-20SR3, KLV-21SG2, KLV-21SR2, KLV-23HR2, KLV-26HG2, KLV-27HR3, KLV-30HR3, KLV-L23M1, KLV-L32M1
TD
Subject
IRIS
Repair Procedure in Case of B / BL / BP Board Replacement [REVISION 1]
No picture, shifted picture, incorrect format settings, incorrect model indication in the service menu.
CAUSE
Empty NVM IC on the B / BL / BP Board.
Before installing the replacement board as listed below, transfer the NVM IC from the original board to the new board.
Model
Board
Original part number
Part number supplied
NVM
Chassis
KE-P37M1
BP
A-1052-753-A
A-1072-158-B
IC1004
AT2M
KE-P42M1
BP
A-1052-753-A
A-1072-158-B
IC1004
AT2M
KLV-15SR1
B
8-933-600-30
8-933-600-30
IC2
AT1
KLV-15SR2
B
A-1302-916-A
A-1302-413-B
IC1008
AT2
KLV-17HR1
B
8-933-600-37
8-933-600-37
IC2
AT1
KLV-17HR2
B
A-1302-915-A
A-1302-412-C
IC1008
AT2
KLV-17HR3
B
A-1071-579-A
A-1071-579-A
IC0103
WA1
KLV-20SR3
B
A-1068-280-A
A-1068-280-A
IC0103
WA1
KLV-21SG2
B
A-1302-899-A
A-1302-899-A
IC1008
AT2
KLV-21SR2
B
A-1302-914-A
A-1302-415-C
IC1008
AT2
KLV-23HR2
B
A-1302-913-A
A-1302-414-B
IC1008
AT2
KLV-26HG2
B
A-1302-899-A
A-1302-899-A
IC1008
WA1
KLV-27HR3
B
A-1081-018-A
A-1081-018-A
IC0103
WA1
KLV-30HR3
B
A-1081-018-A
A-1081-018-A
IC0103
WA1
KLV-L23M1
B
A-1073-463-A
A-1073-363-B
IC1008
AT2M
KLV-L32M1
BL
A-1052-729-A
A-1073-782-B
IC1004
AT2M
