Автор Тема: 04TV107  (Прочитано 319 раз)
04TV107
« : 29 Ноября 2023, 04:15:36 »
04TV107
KLV-20SR3 BC
Subject IRIS
Vertical Jumping during VCR Playback in SECAM Mode F35B
During the playback of a SECAM tape in the SECAM mode, the following
symptoms may occur:
• Vertical picture jumping.
• After pressing the button sequence PAUSE => FF => PAUSE => REW =>
… => PLAY, some garbage may appear at the bottom of the screen.
1. Open the service connector lid at the rear of the set, and use TRACE to read the NVM data. Load the set's
NVM data to the PC using the "TRACE Data Handling" menu. Select Page A4 and note down all the data
corresponding to the addresses listed in the table below.
Address (Hex) Description Data
0464 NORMAL PAL RD
0465 NORMAL PAL GD
0466 White NORMAL PAL BD
0467 Balance NORMAL PAL RC
0468 NORMAL PAL GC
0469 NORMAL PAL BC
0492 SEC2_YDC
0493 SEC2_YGAIN
0494 SEC2_CGAIN
0495 SEC2_UGAIN
049A PAL_YDC
049B AD PAL_YGAIN
049C Adjustment PAL_CGAIN
049D PAL_UGAIN
04A2 SEC_YDC
04A3 SEC_YGAIN
04A4 SEC_CGAIN
