Автор Тема: 04TV082R1  (Прочитано 418 раз)
04TV082R1
« : 29 Ноября 2023, 04:10:48 »
04TV082R1
KE-P37M1
BC
Subject
IRIS
Power Saving Mode Problem [REVISION 1]
137X
Customers may complain that:
• There is no function of the POWER SAVING feature.
• The POWER SAVING mode does not work.
• There is no apparent change of the set during POWER SAVING REDUCE mode.
Connect the service jig board (TL1 Board) to the TV and the PC, and update the software of the main microcomputer (IC1002 on the BP Board) to version 1.200 or higher as explained below.
04TV082 - AT2M PDP - Power Saving Mode Problem [REVISION 1]
« Последнее редактирование: 29 Ноября 2023, 15:20:37 от aze1959 »
