Автор Тема: 04TV071  (Прочитано 237 раз)
04TV071
« : 29 Ноября 2023, 04:09:42 »
04TV071
MBD-MRX1, MBT-MRX1 BC
Subject IRIS
Unstable Picture With Vertical Sync Jumps 234X
Depending on the power supply tolerances of the G Board, the following problems may occur within twenty
seconds after a cold start (discharged mains block capacitors). This is clearly shown in the Error Menu by IC
UDA1380 increasing the error counter.
• Unstable picture with vertical sync jumps (ever 0.3 sec) during the first twenty seconds. After that the picture
recovers itself.
• No audio, even after switching channels or increasing the volume. This problem can be solved by switching
OFF/ON or to Standby.
• The SCART video outputs are muted during the first twenty seconds. After that the picture recovers itself.
Replace the SMD capacitor C8670 on the A1 Board with any of the discrete capacitors listed below.
Former New
Ref. Description Part number Description Part number
C8670 47μF 16V SMD 1-126-204-21 4.7μF 25V 1-127-510-00
4.7μF 35V 1-115-866-11
4.7μF 50V 1-126-163-11
4.7μF 100V 1-107-928-11
