Автор Тема: 03TV027  (Прочитано 215 раз)
03TV027
« : 29 Ноября 2023, 03:56:54 »
03TV027
KLV-15SR2, KLV-17HR2, KLV-21SR2, KLV-23HR2 DP
Subject IRIS
Auto Programming Problem with ACI Signal 1262
When receiving the signal from certain cable companies transmitting ACI signals, only the first channel may be
stored during auto programming.
Preliminary Measure
First select "–" (i.e. no country) in the menu sequence "Set Up", "Country", then perform the auto programming.
The channels will be stored by frequency. Afterwards, apply "Programme Sorting" to set the channels in the
preferred order.
Software Update
Connect the service jig board (TL1 Board) as shown and update the main microcomputer's software to version
1.301 or higher as explained below.
