Автор Тема: 23TV004  (Прочитано 216 раз)
23TV004
« : 30 Сентября 2023, 21:03:45 »
23TV004
APE2 Chassis
Subject: How to use the T-CON JIG with APE2 chassis
Correctly identify the panel problems before trigger an AEP event.
APE2 chassis has a different T-CON connector on T-CON side that it is not compatible with the flex cable provided with the JIG.
