Автор Тема: 22TV025 R1  (Прочитано 246 раз)
22TV025 R1
« : 17 Сентября 2023, 21:43:36 »
22TV025 R1
GR2VH FS, FSL, FT segments
Subject
Static hissing sound can be heard from the TV when Center Speaker mode is used (soundbar connection) [REVISION 1]
SYMPTOM Static noise from the TV when the TV is used as a center speaker in a setup with the HT-A7000 / HT-A9 /HT-A5000 soundbars (any other soundbar capable of this functionality can also impact the set with the same problem).
Models affected: A75K, A80K, A83K, A84K, X90K, X92K, X93K and X94K Series
CAUSE
Depending on noise level, the cause can be different. Please check SOLUTION section.
