Автор Тема: 22TV021  (Прочитано 354 раз)
22TV021
« : 17 Сентября 2023, 21:35:26 »
22TV021
GR2TP chassis (X72K / X73K model)
Subject: How to change serial number / Panel ID (GR2TP chassis)
Serial number and Panel ID can be updated by following the below procedure.
1) Enter Service mode: in any source (TV/HDMI…etc), press 1 2 3 6 5 4 by remote control.
2) Service mode will be displayed on the screen.
3) Check the panel used in the set in order to know the correct 'ADC model' name. Check in the attached 'APE2_Panel_ID.xlsx' file.
4) Unzip the attached ‘APE2_TPVFactoryService.zip‘. Change the ' SETTYPE' and serial number in the 'TPVFactoryService.cookie' file.
5) Save the corrected 'TPVFactoryService.cookie' file in the root directory of a USB flash drive.
6) Insert USB flash drive into USB port while TV working in Service Mode.
7) Wait for system update from USB flash drive. The TV will prompt "Apply Cookie Done!“ when update
 KD-43X72K/P CEI     SONY     KD-43X72K/P CEI     INX TPT430WR-J1Q01.N SD2X     " LVM430J1Q1BSB01H0X
750TBV430Q1NX8N000"    E43L22NBFCSNN     E43LD2NBFCSN2ZX     E43LD2NBFCSNNZT    KD-43X72K_1
 KD-43X72K/P UKA     SONY     KD-43X72K/P UKA     INX TPT430WR-J1Q01.N SD2X      LVM430J1Q1BSB01H0X     E43L22NBFCSYN     E43LD2NBFCSY2ZX     E43LD2NBFCSYNZT    KD-43X72K_1
 KD-43X73K/P CEI     SONY     KD-43X73K/P CEI     INX TPT430WR-J1Q01.N SD2X      LVM430J1Q1BSB01H0X     E43L22NBFCS2N     E43LD2NBFCS22ZX     E43LD2NBFCS2NZT    KD-43X73K_1
 KD-50X72K/P CEI     SONY     KD-50X72K/P CEI     INX TPT500WR-DJ7QE1.N SD1S    " LVM500J7E1BSB81H0X
750TBV500VJ7S8N000"    E50L22NBFCSNN     E50LD2NBFCSN2ZX     E50LD2NBFCSNNZT    KD-50X72K_1
 KD-50X72K/P UKA     SONY     KD-50X72K/P UKA     INX TPT500WR-DJ7QE1.N SD1S     LVM500J7E1BSB81H0X     E50L22NBFCSYN     E50LD2NBFCSY2ZX     E50LD2NBFCSYNZT    KD-50X72K_1
 KD-50X73K/P CEI     SONY     KD-50X73K/P CEI     INX TPT500WR-DJ7QE1.N SD1S     LVM500J7E1BSB81H0X     E50L22NBFCS2N     E50LD2NBFCS22ZX     E50LD2NBFCS2NZT    KD-50X73K_1
