Автор Тема: TV200313  (Прочитано 765 раз)
TV200313
« : 22 Марта 2015, 17:25:11 »
Ref: ENG111303
Product: Projection TV Date: 11/13/03
Models: 27A41
This Technical Bulletin serves as a supplement to the original Service Manual, file number (050-200109). Please refer to this
bulletin in conjunction with the original Service Manual when servicing this model.
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety
precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety
features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to
possible injury.
Application: The information contained in this bulletin applies only if you encounter the
symptom(s) listed below.
Subject: Two Microprocessor versions used in Model 27A41
Symptom: Dead Set after replacement of the Microprocessor (IC101)
Corrective Action: Two non-interchangeable microprocessor versions were used in
this model. (May 2001 a running change was made on this microprocessor
implementing the B version, this change is NOT backward or forward compatible)
Replace the microprocessor (IC101) using the correct version. Identify the correct
microprocessor by visually inspecting the vendor numbers on the device. Use the
information provided below:
Original version OEC7054A Use Part Number AD300051
