Автор Тема: TV200312  (Прочитано 763 раз)
TV200312
« : 22 Марта 2015, 17:24:19 »
ENG111103
Product: Projection TV                               Date: 11/11/03
Models: 51H83, 57H83 and 50A62
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin.  All safety
precautions and checks shall be complied with before returning the equipment to the customer.  Servicers who defeat safety
features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to
possible injury.
Application: The information contained in this bulletin applies only if you encounter the
models(s) in the serial number ranges listed below.
Subject: Capacitor Inspection on Models 51H83, 57H83 and 50A62.
Information Item: When Service intervention is necessary on Projection TV Models
51H83, 57H83 and 50A62, the following procedure must be fully
completed as described in the following steps:
1) Compare the Model / Serial Number of the set requiring service to the Model / Serial
Number range indicated below.  Units that are NOT within the below indicated Model /
Serial Number range require no further service intervention as the result of this
Technical Bulletin.  Units that ARE within the Model / Serial Number range must be
inspected using the “Inspection Procedures” as described on page 2 of this Technical
