Автор Тема: TV0201  (Прочитано 764 раз)
TV0201
« : 22 Марта 2015, 17:01:11 »
Models4: 2 H81 43H71 43HX71 50H71 50H81 5601HHX7811 656565535353HHHHHH87878711111 656565535353HHHHXXXX8787871111 57H81 57HX81
Application: The information within this bulletin should only be used if you
encounter the symptom(s) listed.
Symptom: Power LED lights. Power supply does not start.
Corrective Action: Check the solder connections at the negative side of both C809 and
C810. Resolder if necessary. Poor connections could possibly open fuse
F860. Check the fuse and replace if necessary.
