Автор Тема: TV 200204  (Прочитано 795 раз)
TV 200204
« : 22 Марта 2015, 16:55:03 »
Ref: 02A-200208
Product: PJTV Date: 5/14/02
Models: 42H81, 43H71, 43HX71, 50H71, 50H81, 50HX81, 53H71, 53HX71, 57H81,
57HX81, 61H71, 65H81 and 65HX81 having serial numbers beginning with: 14, 15,
17, 18, 19, 20, 21, 22, 25, 29, 31, 37, 39, 42, 50, 58, 60, 64, 70, or 75.
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety
precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety
features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to
possible injury.
Application: The information contained in this bulletin applies only if you encounter the
symptom(s) listed below.
Subject: No eyelet on circuit board at negative terminal of C809 and/or C810.
Possible dry solder joint may cause main fuse to blow.
Symptom: Main fuse (F801) blows
Corrective Action: Re-solder negative terminals of C809/C810. Make sure negative
terminal of C809 and/or C810 makes a firm connection.
