Автор Тема: PDP200301  (Прочитано 842 раз)
PDP200301
« : 22 Марта 2015, 16:50:31 »
3 Pages Ref: WU102803
Product: Plasma TV Date: 10/28/03
Models: 42HP83
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety
precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety
features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to
possible injury.
Application: The information contained in this bulletin applies only if you encounter the
symptom(s) listed below.
Subject: Technical Repair Information
Symptom: Green flashing in the picture and/or dark picture. (Note: Multiple symptoms
could be exhibited with this problem)
Corrective Action: Inspect for correct seating of the G-Hyper Module following the
procedure described below:
1) Locate the G-Hyper Module and remove the two securing screws. See Fig. 1
2) Inspect the rear connector of the G-Hyper Module by slightly tilting the upper side
of the module away from its mounting position, no more than 1 inch.
