Автор Тема: 19TV028R0  (Прочитано 289 раз)
19TV028R0
« : 09 Июля 2023, 14:45:57 »
19TV028R0
KD-98ZG9
Subject: Horizontal top line noise.
H-Line noise occurs in top of the screen for several minutes.
Bottom line signal of previous frame wrongly reflected on top line of current frame.
- if top and bottom signal patterns are same, the noise cannot be seen.
- if top and bottom signal patterns are similar, the noise is hard to find.
CAUSE
Memory read/write access timing corruption.
Read/Write timing margin is not enough, so in case of jitter occurs, T-CON internal memory access corruption happens. In this case, end of previous frame data is wrongly reflected as line noise of top line.
Replace T-CON Board with Part Number like indicated below.
Description
Part number
MOUNTED PWB E-T-CON(98)
100121911
« Последнее редактирование: 07 Декабря 2023, 07:51:30 от aze1959 »
