Автор Тема: 19TV002R1  (Прочитано 230 раз)
19TV002R1
« : 09 Июля 2023, 10:37:59 »
19TV002R1
GN4UR chassis
Subject: Vertical bar [REVISION 1].
Note: AEP event or Main Board exchange is not allowed.
Vertical bars visible on screen after a big amount of input selections.
CAUSE
SoftWare issue.
Issue solved with SoftWare PKG 6.0744 or above that is available in the Technical Bulletin 18TV021.
Intermediate solution is switch the AC of the set OFF and ON.
Main Board exchange or AEP event will not solve the issue.
« Последнее редактирование: 06 Декабря 2023, 22:41:29 от aze1959 »
