Автор Тема: 19TV001R0  (Прочитано 238 раз)
19TV001R0
« : 09 Июля 2023, 10:36:21 »
19TV001R0
GN4UR_CX
Subject: TV set handling precautions. Finger pinch prevention.
Set handling caution when TV set is unpacked and set up.
CAUSE
In order to produce an ultra-slim design the panel strength is not strong from construction point of view and need to be handled carefully.
Handle TV set carefully to prevent panel pinch.
1. Open Top flap ① of carton, take out Top cushion and lift up the Carton ②.
2. “Cell Protector ③“ is sticked on the left/right side of the panel to prevent panel pinch when handling.
Please don’t remove “Cell Protector ③“ from the set until the TV is set up or wall mounting is finished.
« Последнее редактирование: 06 Декабря 2023, 22:23:36 от aze1959 »
