Автор Тема: 18TV022R2  (Прочитано 321 раз)
18TV022R2
« : 09 Июля 2023, 10:34:40 »
18TV022R2
KD-49XF85xx, 49XF8796 KD-49XG83xx
Subject: T-con Board Replacement [REVISION 2].
Different non-compatible T-con boards for the listed model have been registered for service.
CAUSE
Manufacturer change.
In case of any T-con board failure replace the T-con board according to the part number info below.
O-cell
T-con
Vendor P/N
Sony P.N.
Vendor P/N
Barcode label
Sony P.N.
LSY490FF01-B01
181240411
LMY490FF01-B01
X40847Wxxxxxx
189727511
X40847Rxxxxxx
LSY490FF01-D01
181240412
LMY490FF01-D01
X40847Yxxxxxx
189727512
X43057Axxxxxx
LSY490FF02-B01
181240413
LMY490FF02-B01
X42770Gxxxxxx
189727513
T-con barcode label:
IMPORTANT: When the T-Con board is replaced please apply the actions described from page 6 onwards in the “Service Procedure for Panel, Board and Software Change / Upgrade” available in ASSIST under Doc Ref 98887590x
« Последнее редактирование: 06 Декабря 2023, 22:08:45 от aze1959 »
