Автор Тема: 18TV018R0  (Прочитано 240 раз)
18TV018R0
« : 09 Июля 2023, 10:29:29 »
18TV018R0
GN3TR-KS/KH
Subject: Horizontal green bars on screen (FRC-pattern)
In the KS and KH series, due to a defect in the FRC (Frame Rate Control) IC of the mainboard, FRC patterns are generated in which the screen is split horizontally into lateral green noise bars.
CAUSE
IC4600 FRC voltage problem on the mainboard.
Replace the mainboard. This is not a panel fault (do not create AEP exchange!)
« Последнее редактирование: 06 Декабря 2023, 22:04:37 от aze1959 »
