Автор Тема: 18TV014R0  (Прочитано 239 раз)
18TV014R0
« : 09 Июля 2023, 10:02:09 »
18TV014R0
GN4TR_CHM
Subject: TV set handling precautions. Finger pinch prevention.
Set handling caution when TV set is unpacked and set up.
CAUSE
In order to produce an ultra-slim design the panel strength is not strong from construction point of view and need to be handled carefully.
Handle TV set carefully to prevent panel pinch.
* KD-70XF8305
1. Open Top flap① of carton, take out Top cushion and lift up the Carton②. Then remove Front board ③. Like illustrated in the below pictures.
2. “Cell Protector④“ is sticked on the left/right side of the panel to prevent panel pinch when handling.
Please don’t remove “Cell Protector ④“ from the set until the TV is set up or wall mounting is finished.
« Последнее редактирование: 06 Декабря 2023, 20:50:27 от aze1959 »
