Автор Тема: 18TV009R0  (Прочитано 255 раз)
18TV009R0
« : 08 Июля 2023, 14:40:43 »
18TV009R0
KD-75XF8596
Subject: TV set handling precautions. Finger pinch prevention.
Set handling caution when TV set is unpacked and set up.
CAUSE
In order to produce an ultra-slim design the panel strength is not strong from construction point of view and need to be handled carefully.
Handle TV set carefully to prevent panel pinch.
1. Open the Top flap ① of the carton box, take out the Top cushion and lift up the Carton ②. Then remove the Front board ③. Like illustrated in the below pictures.
2. “Cell Protector④“ is sticked on the left/right side of the panel to prevent panel pinch when handling.
Please don’t remove “Cell Protector ④“ from the set until the TV is set up or wall mounting is finished.
« Последнее редактирование: 06 Декабря 2023, 18:57:30 от aze1959 »
