Автор Тема: 17TV027R0  (Прочитано 200 раз)
17TV027R0
« : 08 Июля 2023, 13:59:32 »
17TV027R0
GN3TR_KA chassis
Subject: HARNESS ASSY (MAIN) incompatibility / TSA2_KA change.
Two different incompatible HARNESS ASSY (MAIN) are used during production.
TSA2_KA board is no longer included in the set.
CAUSE
Manufacturer change
Replace as long as available with the HARNESS ASSY (MAIN) as original installed in the set.
Description
Part number
Remark
Before change
HARNESS ASSY (MAIN)
1-910-112-44
with connector for TSA2_KA-board
After change
HARNESS ASSY (MAIN)
1-910-112-54
without connector for TSA2_KA-board NOTE:
- Don’t use the HARNESS ASSY (MAIN) with connector to TSA2_KA board if no TSA2_KA board is in the set.
- You can use HARNESS ASSY (MAIN) without connector to TSA2_KA board if TSA2_KA board is in the set. (TSA2_KA board not connected)
« Последнее редактирование: 06 Декабря 2023, 14:51:33 от aze1959 »
