Автор Тема: 17TV026R0  (Прочитано 211 раз)
17TV026R0
« : 08 Июля 2023, 13:55:41 »
17TV026R0
GN3TR_KA chassis
Subject: CONNECTOR ASSY 40P compatibility.
Two different compatible ‘ CONNECTOR ASSY 40P(PWRT) ‘ cables are used during production.
CAUSE
Manufacturer change
Both cables can be used, although, replace as long as available with the connector assy as original installed in the set.
Description
Part number
Remark
Before change
CONNECTOR ASSY 40P(PWRT) (w core)
1-910-112-46
With core
After change
CONNECTOR ASSY 40P(PWRT) (w/o core)
1-910-112-55
Without core
« Последнее редактирование: 06 Декабря 2023, 13:35:11 от aze1959 »
