Автор Тема: 17TV024R0  (Прочитано 263 раз)
17TV024R0
« : 08 Июля 2023, 13:54:10 »
17TV024R0
GN3TR_KA
Subject: SPeaker COVER incompatibility, cushion Actuator change.
Two versions of SP COVER have been used during production. OLD Suffix (without cushions) NEW Suffix (with cushions).
KD-55A1
KD-65A1 / KD-77A1
COVER SP A (L HKS)
COVER SP A (2L HKS)
OLD Suffix
OLD suffix
R (w Logo)
L (w/o Logo)
R (w Logo)
R (w/o Logo)
4-688-500-01
4-688-500-11
4-688-504-01
4-688-504-11
NEW Suffix
NEW Suffix
R (w Logo)
L (w/o Logo)
R (w Logo)
R (w/o Logo)
4-688-500-02
4-688-500-12
4-688-504-02
4-688-504-12
CAUSE
Design change to improve working efficiency.
If SP COVER replacement is needed, please order as long as available the original SP COVER.
- If cushions attached to the Actuator of the panel
-> OLD suffix SP COVER
- If no cushions attached to the Actuator of the panel
-> NEW suffix SP COVER
If a change is needed, make sure to remove or stick cushions like illustrated in below tables.
User’s TV
TV with
OLD suffix COVER SP A
TV with
NEW suffix COVER SP A
Replacement
part
which you use
OLD suffix
COVER SP A
Only replace speaker cover
Need to stick cushions to the actuator on the panel
NEW suffix
COVER SP A
Need to remove cushions of the Actuator on the panel
Panel
(for panel repair centre only)
Do not stick cushions to the Actuator on the panel
« Последнее редактирование: 06 Декабря 2023, 13:32:39 от aze1959 »
