Автор Тема: 17TV023R0  (Прочитано 197 раз)
17TV023R0
« : 08 Июля 2023, 13:48:17 »
17TV023R0
KD-65XE9005
Subject: BT ANTENNA handling, Panel Module compatibility.
Two versions of panel module have been used during production (2 dowels – no dowels on Source Shield).
If BT ANTENNA replacement is needed, make sure that the BT ANTENNA is mounted parallel with the edge of the SOURCE SHIELD like illustrated in the below picture.
« Последнее редактирование: 06 Декабря 2023, 13:21:12 от aze1959 »
