Автор Тема: 19TV013R7  (Прочитано 371 раз)
19TV013R7
« : 07 Июля 2023, 11:02:07 »
19TV013R7
GN5UN_SV Chassis
Subject: Software packages follow-up for GN5UN_SV chassis [REVISION 7].
SW version: 8.609
Link: sony_tvupdate_2017_8609_enf_auth.zip
Update with the latest software package, following the abridged procedure below.
NOTE: For full software procedure please check Service Manual.
1. Download the applicable file from the link mentioned in the header, unzip and copy the extracted file to the root of an empty USB stick.
2. Turn the unit ON.
3. Insert the USB memory into the USB port located at the side of the unit.
4. Go to USB update
Press [HOME], and select ‘Settings’ > ‘Customer Support’ > ‘Software Update’ > ‘USB’
5. A series of different messages will appear on the TV set. Please follow the on screen instructions
6. During System update, the LED indicator slowly flashing amber.
7. After several minutes, the Software update complete message displays. And the TV will turn off automatically and then turn back on to complete the update. IMPORTANT: During the firmware installation process, do not remove the USB device, switch off theTV set or remove the power. After the TV turn on, Safely remove your USB device from the USB slot
After the TV turn on, safely remove your USB device from the USB slot
DTV02B40B0AB4BE_00100100_8609
« Последнее редактирование: 07 Декабря 2023, 04:58:36 от aze1959 »
