Автор Тема: 16TV005R1  (Прочитано 527 раз)
16TV005R1
« : 06 Июля 2023, 15:23:50 »
16TV005R1
Models GN2S_QWL Chassis
Subject: Software packages follow-up for GN2S_QWL chassis [REVISION 1].
The latest software packages have been released, remedying the issues below. Issues
IRIS code
Section code
Segment
Rev. Wrong ‘electronic Pre-installed Onscreen Promotion’ in Demo mode.
C739
SWA
ALL
R0 slow response (when changing channels) or freezing
6154
SWO
ALL
R1 Intermittently TV won’t turn On by RC or side key (AC OFF/ON required)
2119
SYS
Update with the latest software version, by following the abridged procedure below.
NOTE: For full software procedure please check Service Manual 9-888-196-xx.
1. Download the applicable file attached to this Technical Bulletin, unzip and copy the extracted file to the root of an empty USB stick.
Date
SW version
September 2016
GN2S_QWL_v8518_TDEU1.zip
8.518
2. Turn the unit ON.
3. Insert the USB memory into the USB port 1 located at the side of the unit.
4. Pull Out the AC plug and wait 10 second (considering the charge of AC adaptor).
5. Press the
key located on the lower part of TV and hold it while inserting the AC plug.
GN2S 2016 8518 TDEU1
« Последнее редактирование: 06 Декабря 2023, 03:02:48 от aze1959 »
