Автор Тема: 15TV008R11  (Прочитано 439 раз)
15TV008R11
« : 06 Июля 2023, 13:09:38 »
15TV008R11
Software packages follow-up for GN1S_SE2N chassis [Revision 11]
SW version: 8.591
Attachment: sony_tvupdate_2015_8591_enf_auth.zip
Update with the latest software version, by following the abridged procedure below.
NOTE: For full software procedure please check Service Manual 9-888-173-xx.
1. Download and unzip the applicable file attached to this Technical Bulletin and copy the extracted file to the root of an empty USB stick.
2. Turn the unit ON.
3. Insert the USB memory into the USB slot located at the side of the unit.
4. Pull Out the AC plug and wait 10 second (considering the charge of AC adaptor).
5. Press and hold the side Power Key for 5 seconds and re-insert the AC plug at the same time.
After 20~30 seconds, the LED starts blinking in amber.
LED blinking indicates that the SW Update is ongoing. IMPORTANT: During the firmware installation process, do not remove the USB device, switch off the TV set or remove the power.
6. After 1~2 minutes, the LED stops blinking. Press the unit [Power] key.
If “SONY” appears on the screen and the LED turns ON in green, the software update succeeds.
7. Pull out the USB memory from the unit.
15TV008 - Software packages follow-up for GN1S_SE2N chassis [Revision 11]
DTV02B10B03B1B3_00100100
gn1s_se2n_v8582_sleua
15TV008R6
Date Attachment SW version
November 2015 GN1S_SE2N_v8582_SLEUA.zip 8.582
« Последнее редактирование: 05 Декабря 2023, 12:57:31 от aze1959 »
